porting H Farmall head/manifold
redcub
10-07-2005 16:02:40
What will I gain if I port my head and manifold on my H Farmall (stock bore/stroke with 152 lbs. compression? How far can you go without getting into the water jacket--should I use the gasket as my guide? Should I leave it alone? Thanks for the helpful opinions.
Charles McNelly III
10-09-2005 19:11:01
 Re: porting H Farmall head/manifold in reply to redcub, 10-07-2005 16:02:40
Just remember when porting a low rpm engine, its real easy to go to far. You have to keep the velocity up on these engines for the power. I would just blend the ports.
