motor work on a M farmall
jms1066
10-06-2005 20:25:44
what is a good sleeve and piston set when rebuilding a 1950 M farmall it does have the high compression head. and add anymore hints for more power thank you all
jms1066
10-10-2005 19:32:23
 Re: motor work on a M farmall in reply to jms1066, 10-06-2005 20:25:44
thank you all for the great input any other ideas
B Barenie
10-07-2005 03:41:15
Forget the sleeves, run on the existing bore, less the sleeve !
jms1066
10-09-2005 19:10:28
 Re: motor work on a M farmall in reply to B Barenie, 10-07-2005 03:41:15
will this really work or will it be bad for the motor
Bbarenie
10-10-2005 16:52:06
 Re: motor work on a M farmall in reply to jms1066, 10-09-2005 19:10:28
will what really work, please get a copy or buy a subscription of old power pride (m) build-up of last winter !
forget the sleeves, read the articles, and you all decide !!!!!
good night !
jms1066
10-09-2005 19:10:56
b barenie
10-10-2005 16:54:42
 Re: motor work on a M farmall in reply to jms1066, 10-09-2005 19:10:56
in who'slife time is it going to wear out in !
haaaa ! well the bore it another 30thds
haaaa !
ChadS
10-10-2005 09:13:52
It could run forever like that, but once it wears out, its done, there is no overbore pistons for 4-1/8th bore for a SM-450. If you want the 4-1/8th bore, just have the M block fitted with the 450 sleeves. That way you have something that is rebuildable, still have the original block in the tractor, (if rules keep you from running the later blocks) If they dont, then find a late model block. You would have to bore the M block to 4.25 for the 450 barrel diameter, and fit the sleeve flange to fit as well. In my opinion, Id have the 450 sleeve flange cut down in diameter to match the M specs, that way, your not weakening the top of the block deck, yeah it cost a little more, and be more of a hassle come time to rebuild if you ever had to. But the block would be safer. Just my 2 cents, Chad
