stalling a 70D
jman
10-06-2005 20:07:19
Will a 70d "run backwards" if pulled down too low?
If so what to do?
JPatton
10-07-2005 15:07:00
 Re: stalling a 70D in reply to jman, 10-06-2005 20:07:19
Yeah, a 70D will run backwards. Back in '55 we bought a new one. Seemed like that tractor spent more time running backwards than it did forwards. It wasn't like the ole "D" that you could lug down 'til it was about to take its last breath. When that 70 lugged down and you were too slow with the clutch, you knew it right away. Two things happen: First, you can't see cause all the oil that was in the oil bath air cleaner is now in you eyes and second, you better hope you were pulling something like a mounted plow. I backed up over a rotary hoe one time. Took my whole summer wages to pay for that replacement tire. I was 12 years old at the time. Guess is should have listened to Dad and been in 5th gear instead of 6th. I just thought if I was in a higher gear, I would get done faster.
J
Rousseau
10-07-2005 05:10:14
YES BUT its hard to do.If it happens pull the decompression lever.
