Tire Pressure - What do y'all run ?
Lamont
10-06-2005 19:51:10
I pull a Case 700 in the Open 4 and 8 MPH, 5500 to 7500 lb. classes. It has 18.4 x 38 Firestone 151 cuts on it. I've been running 12 psi and losing traction. Last time I ran 9 psi and it seemed better. What are you guys with similar weights and tire size running? Should I back on off to 7 or 7.5 psi ? Is there a general rule or just trial and error? Thanks.
mo air
10-07-2005 11:14:24
 Re: Tire Pressure - What do y'all run ? in reply to Lamont, 10-06-2005 19:51:10
I run no less than 14 lbs. in the 5500 lb. class. Just look at the holes you dig when you spin out. If the tire didn't dig a flat hole, i.e. if the middle of the hole sticks up higher than the edge, you need more air because the tire is "cupping". And if the middle is deeper than the edge it's vice versa. You don't want the tire to squat either, all that does is lower your drawbar. Just flatten out and stay there.
bradd
10-07-2005 06:24:18
Lamont it will differ on track to track. one way to gauge tire pressure it to look at your tracks when you pull forward from the sled. You want your tracks to be almost level where you spun out. If the track is high in the middle you need a little more air pressure, if it is low or rounded down in the middle you coud stand a little more. also look at the lugs on your tires you can usually tell how much of your lug was hooking up.
Lamont
10-07-2005 10:22:43
 Re: Tire Pressure - What do y'all run ? in reply to bradd, 10-07-2005 06:24:18
That part makes sense. What do you think about when you need more air pressure? Looser/soft tracks or tighter/hard tracks? Is there a general rule?
AOOC
10-07-2005 16:58:17
 Re: Tire Pressure - What do y'all run ? in reply to Lamont, 10-07-2005 10:22:43
General rule is hard track hard tire..soft track soft tire...much varies on type of tire, how worn it is etc..just gotta play with it.
Turtle Gears
10-07-2005 17:53:02
 Re: Tire Pressure - What do y'all run ? in reply to AOOC, 10-07-2005 16:58:17
hey guys, what if your tractor gets at the end of its pull and it dont spinout? 2-much air or not enough power??T.G.
cts
10-09-2005 16:13:31
 Re: Tire Pressure - What do y'all run ? in reply to Turtle Gears, 10-07-2005 17:53:02
Great tire pressure,More HP needed
