Rebuilding H Sleeve Quest
MagMan
10-06-2005 04:25:24
Hi guys, I am putting this H motor together and the block was dipped blasted and checked, Ok when I put the sleeves in I put a little fuel oil on them and the two center ones slid right in with just a little wobble back and forth. The front and rear went down about 75% and went fairly easy with a rubber hammer and wood block.While I was installing the pistons and turning the motor one of the center sleeves was moving with the piston in the block. Do I need to put something around them like sleeve set or is this all right when the motor is together. Also There is a round plate shaped cover that goes over the front end of the crank some how and I cant find it in the parts paper I have Does anyone know where it goes exactly I think its like a something to keep oil back or something.Thanks JON
randy hall
10-06-2005 18:43:50
 Re: Rebuilding H Sleeve Quest in reply to MagMan, 10-06-2005 04:25:24
if you don't use something to glue those loose sleeves in [i use 680 locktite] you will end up with a case of 560 itis. the sleeves will end up in the oil pan. your overhaul kit should have instuctions that say that the sleeves should fit in by hand half way then tap in with a wood block the rest of the way.
Mike S 806/H
10-06-2005 12:10:49
I had the same problem with my H, The guy at the machine shop said to use sleeve retainer to install the sleeves, this way it will transfer the heat from the sleeves to the block.
ChadS
10-06-2005 08:58:41
Jon, I usually hone the block lightly with a bead hone, clean out the block bores, and spray a little coating of WD40 before installing the sleeves. The headgasket helps hold the sleeves in place from torque from the head studs. Probably with a little runnng time the sleeve might seat in and stay put. If it comes out easily, remove it, clean off the oil and reinsert the sleeve, see if that makes it a little harder to move. The large round ring is a shield for the oil seal. It keeps direct contact with engine oil away from the seal, it should have a key way cut into it for it to slide over the crank key, and then drive the damper pulley back on tight against the ring. That holds the shield in place. Face the tapered edge towards the timing cover. Hope this helps. Chad
MagMan
10-06-2005 15:03:12
 Re: Rebuilding H Sleeve Quest in reply to ChadS, 10-06-2005 08:58:41
Ok thanks Chad But That oilcup goes behind the front cover? or on the out side of it? there is no key way in it just a perfect round hole but I must ahve taken the key off before the cup I guess. Its been like a year since I tore her down and the machine shop just finished the pistons and head for me so I am just putting her together its my first complete rebuild I have done sleves before but never gone this far. Its going real slow but I am taking my time and trying to do it right. So far I have only had to disasemble one thing becuase I forgot something . LOL. I would like to get a price on a govener spring from you and maybe even some springs for the dist if you have them. The last I heard from you you found something else in life to pass the lonely nights a little easier and have someone to do fun things with. I hope thats still working out for you. I hope were talking about the same thing with the oil deal its not the seal or felt for the front its deeper I believe. THANKS JON
ChadS
10-07-2005 10:31:01
 Re: Rebuilding H Sleeve Quest in reply to MagMan, 10-06-2005 15:03:12
It goes on before you install the timing cover, the key can help hold it in place from sliding forwards and out of place, once the timing cover is installed, seal in place, drive the pulley on against the oilcup. I have one out, Ill see if I can dig it out, and post the picture to make sure we are on the same page. Yeah, I got married back in August, sweet lady she is. Loves tractors and pulling. Chad
FarmerSid
10-07-2005 04:56:35
third party image
Hey MagMan, here is a few pics from the H parts manual that may help you out with where that oil cup goes. If you want, e-mail me and I will send you the pics and anything else you need.
Cheers!
Sid
FarmerSid
10-07-2005 04:58:49
 Re: Rebuilding H Sleeve Quest in reply to FarmerSid, 10-07-2005 04:56:35
third party image
The other pic. I may have to e-mail them to you so you can zoom in and see it better. E-mail me and I would be glad to send them to you.
Cheers!
Sid
Gmitch
10-07-2005 05:51:13
 Re: Rebuilding H Sleeve Quest in reply to FarmerSid, 10-07-2005 04:58:49
I smear a very thin coat of fine valve grinding compound on them when I run into that. VERY thin.
They get tight fast so be cautious.
