NATPA PULL - Sandusky,MI - NOV 6th
KEDDANO
10-05-2005 14:44:50
third party image
Mark your calender,It's the first points pull of the winter.
superih
10-05-2005 17:20:50
 Re: NATPA PULL - Sandusky,MI - NOV 6th in reply to KEDDANO, 10-05-2005 14:44:50
If I want to pull Saturday, but not in the points does my tractor have to be inspected and approved for the division it will be pulling in? I have never pulled at a NATPA pull but am planning on pulling at this one. (Its close to home)
Keddano
10-06-2005 09:27:11
 Re: NATPA PULL - Sandusky,MI - NOV 6th in reply to superih, 10-05-2005 17:20:50
My tractor will have to pull in Div 3 NATPA because of the carb,intake,top cut tires,and side shields....But it is a Div 2 puller under EMTPA's rules because it is not stroked and meets the 18" & 24" hitch rules.Div 2 is allowed to run top cut under the rules of EMTPA. The biggest things that might tag people in all classes (and not allow them to pull with NATPA)is the wheelie bars and hitch configuration.As Charlies saids, read NATPA's rules closely.
Charles Poosch
10-06-2005 04:52:07
Yes, to pull on Saturday you must pass NATPA tech, but for Sunday it is to EMTPA rules. I suggest anyone wanting to run both days read both rule sets carefully as there are small, but significant, differences between the 2.
Hope you can make it!
CP
roger baumeister
10-06-2005 18:35:46
 Re: NATPA PULL - Sandusky,MI - NOV 6th in reply to Charles Poosch, 10-06-2005 04:52:07
could some one send me the rule please my tractor is a 1958 a.c . i whould like to pull boths day thank u roge
advice
10-06-2005 20:20:31
 Re: NATPA PULL - Sandusky,MI - NOV 6th in reply to roger baumeister, 10-06-2005 18:35:46
Roger, go to natpa.com then click on the rules link. You can find the division 2 rules there.
Far as I know, 1958 models are not legal in Div. 2
Charles Poosch
10-08-2005 17:47:16
 unless... in reply to advice, 10-06-2005 20:20:31
your AC is a '57 or older model production running into a later year.
CP
