MM ZA pistons, how big will fit
Jake Winn
10-04-2005 10:22:31
Hello, I would like to build up a ZA for pulliing. How big of piston will fit before the cylinder walls get to thin? Any tricks for this? im not necessarly looking for MM pistons to fit in. Thanks
minniemo
10-06-2005 14:28:05
 Re: MM ZA pistons, how big will fit in reply to Jake Winn, 10-04-2005 10:22:31
Went to 3 3/4 bought ross alum. pistons. did a 1/2 stroke like mopower said get it done right or pay.pay attenion to clearance at the top I got mine at .34 th.
Now get a LP head or take .110th off your gasket surface.Now you know all my little secrets.
Mopower
10-05-2005 06:04:56
I used aftermarket Aluminum 3.81 pistons from Welters Farm Supply in Verona, MO. My blocks were thick enough (3-3/4 +.060 in. bore). The machine shop that did my blocks said they could bore to the end of the hole, but to my displeasure, the pistons hit a slight 1/16 ridge. I used a thicker block gasket and they cleared, but I prefered not too loose that compression. Live and learn I guess.
JK2
10-05-2005 04:37:26
It depends on how badly the water jacket side of the cylinders are pitted. Occasionally one will leak when bored to 3-3/4". There are quite a few around that are bored to 3-3/4" with no problems.
Make sure that whoever bores the jugs knows what they are doing. It takes a special cutter to bore clear to the top of the bore so the pistons won't hit.
John
