77 pistons and sleeves in a 70?
FM
03-08-2002 19:57:07
Can you put sleeves and pistons from an Oliver 77 into an oliver 70 block? If it works, you would have to bore it out, correct? Are the Piston pins the same?
Jerry B
03-11-2002 09:02:29
 Re: 77 pistons and sleeves in a 70? in reply to FM, 03-08-2002 19:57:07
The 70 is a 6 cylinder Continental and the 77 is a Waukesha 6 banger. The 70 has a standard bore of 3.125 and the 77 is 3.5 (if I remember correctly).
The block of the 70 will have to be bored to the point where the sleeves will touch at the top of the block. It has been done but it reduces the life expectancey of the engine.
The wrist pins of the 70 are about 7/8 of and inch and the wrist pins of the 77 are 1.625 (I think).
Jeff
03-09-2002 15:50:50
I`am not an Oliver man but I think a 70 is 4 cylinder and I know a 77 is 6 cylinder
FM...70 is 6 cylinder...Nm
03-09-2002 16:10:37
 Re: Re: 77 pistons and sleeves in a 70? in reply to Jeff, 03-09-2002 15:50:50
mike
