The 560 Diesel Power Puller
Rhody
10-01-2005 19:44:56
Well, that's what I'd like to do. I've a 560 diesel just sitting around doing nothing. Collecting rat nests and rust. I'm going to do a complete tear down and at at a mininum a show tractor, but, if the 560 is a potiential puller, who has the skinny on 560's?
ejr-IA.
10-03-2005 20:27:13
 Re: The 560 Diesel Power Puller in reply to Rhody, 10-01-2005 19:44:56
I pull 560s once in a while no turbo maxed out pump 2o00rpm 6500&7500# farm stock low ta ahead 16.9x38 tires does well.Then the other one has a 301 d with turbo it will pull 2nd gear same wht. Makes around 120hp.at 2800rpm.
Redman
10-02-2005 11:37:00
depends what they are pulling against,they will hold their own against a 4010.
if the 4010 adds a 466 you will not touch him,if a 806 show everyone competes for second.
Rhody
10-02-2005 16:57:17
 Re: The 560 Diesel Power Puller in reply to Redman, 10-02-2005 11:37:00
if the 4010 adds a 466 you will not touch him,if a 806 show everyone competes for second>>>
Now, this means nothing to me. I assume you"re talking a JD and a 466 is some sort of engine. And the 806 is an IH. But again you aren"t adressing what I"m asking.
Regarless what place the 560 may or may not place in competition, I have the tractor.
It"s apparent that indeed 560"s do compete, but what does it take to make it a competant puller?
Redman
10-02-2005 18:51:25
 Re: The 560 Diesel Power Puller in reply to Rhody, 10-02-2005 16:57:17
need the rules,you can get around 750hp out of that engine.
copper head gasket,twin turbos,injectors,P-pump and she will spin around 5000.
can be done,but if that is the rules you will be looking at a open class and you will see 560s with DT466 engines bolted to then running double that hp with the same parts.
in a stock class or a limited rpm turbo class they will do good,bolt on a turbo and turn up the pump and play.
Rhody
10-02-2005 19:20:16
 Re: The 560 Diesel Power Puller in reply to Redman, 10-02-2005 18:51:25
Thanks, Now that gives me some wiggle room to work with.
Find the rule book, figure out which class I want to run, build accordingly.
I'd like to stay with the stock version right now, adding the turbo would be an easy addition. That sounds like the angle right now. If I want to go BIG, I'll get a bigger tractor with a bigger engine... ;o]
Dan
