what else besides 350 kit in the H
KAS
09-28-2005 14:05:19
I am going to bore my H block to accept the 350 kit. While I have it apart what else should I do with it. Also how much will have to bore to make the 350 sleeves to fit.
ChadS
10-04-2005 16:47:50
 Re: what else besides 350 kit in the H in reply to KAS, 09-28-2005 14:05:19
3-3/4 is the barrel size, its a bit less than 4 inches on the sleeve flange. Can be done, if your machinist is worried about the top of the block being enough to fit the 350 sleeves, cut the sleeve flange down to the H specs. go get a 350 cam, and cyl head. SH-350 intake and carb. (if your rules allow) Use the 350 head gasket. Chad
brandonf
10-04-2005 20:44:21
 Re: what else besides 350 kit in the H in reply to ChadS, 10-04-2005 16:47:50
what is a sh350 intake more specifically what does the sh stand for where does someone propose I can find these parts economically... thanks for the help
ChadS
10-05-2005 09:54:10
 Re: what else besides 350 kit in the H in reply to brandonf, 10-04-2005 20:44:21
The intakes were used on the Super H-350 model tractors. This is an upgraded manifold that uses a larger intake, and uses a carb that is simular to the M. The "SH" stands for Super H which was made from 1953-1954, the 300-350 was 54 to late 57. You can find these intakes bout anywhere that sells aftermarket parts, look here at YT in the parts section! if they offer a "Vinson" manifold for their selcetion BUY IT!!! Its a good one. Hope this helps, Chad
brandonf
10-05-2005 22:38:09
 Re: what else besides 350 kit in the H in reply to ChadS, 10-05-2005 09:54:10
thanks for the help I spoke with earl a bit this morning, I am gonna get things going pretty quick thanks brandon, btw I figured out sh this morning, a little after the fact but better late than ever
brandonf
10-04-2005 16:39:56
keep this one too the top I am listening too
