h farmall
oldallisman
09-28-2005 03:05:34
my son is pulling a h farmall, but as soon as it gets under a load, it sounds like the governor isn"t working and just pulls down. Last pull it only went 20ft. any tips is helpful in solving this is greatly accepted.
lil buckshot
08-13-2006 14:09:06
 Re: h farmall in reply to oldallisman, 09-28-2005 03:05:34
you may need to put a stiffer spring in the governer and what i have done is shaved a half ounce off of each governer wheight. Though maybe you might not be getting enough fuel or your valve aren"t closing all the way.Tip for bone stock carbs.Hone out venturi with a brake hone and drill hi main jet out one size bigger.Also might be good to put a set off stiffer valve springs on. I get mine from crane cams.
