JD AR
deere
03-07-2002 15:14:29
I am thinking seriously of building an "AR" John Deere. the tractor is pretty short, so what size rear tires should I put on it? Thanks
chad
03-07-2002 16:47:38
 Re: JD AR in reply to deere, 03-07-2002 15:14:29
id go with whats on it any bigger and yer gonna run into power problems if you build the engine up you still have lotsa gears left to pull at a good speed.....2 cents chad.....
deere
03-07-2002 17:04:43
 Re: Re: JD AR in reply to chad, 03-07-2002 16:47:38
I should have mentioned this earlier, if I build one it will probebly be between 80-90 horsepower.
deere
03-07-2002 17:09:39
 Re: Re: Re: JD AR in reply to deere, 03-07-2002 17:04:43
I also forgot to mention it is a 1937 unstyled model.
MOLE BOY
03-08-2002 11:19:43
 Re: Re: Re: Re: JD AR in reply to deere, 03-07-2002 17:09:39
20.8'S SHOULD WORK!
