Cohocton/Full Pull H
Kevin
09-26-2005 19:17:01
Full Pull H,
I think i am going to bring the massey harris out to cohocton. Its probly going to be about 1 hour and 40 minutes 1 way for me but it should be worth it. Were do you leave from? I think im leaving the H at home. Also i dont want to go unless i know i have suit case weights to borrow. Do you know anyone that could let me use some? I need about 13 100lb weights for the 6500 lb class. If there is any doubt of me having weights available im not even going to come out. If i do come out i will run 5500 and 6500 stock unless i build a lighter middle weight bracket so i can run 4500.
upperpinecreek
09-29-2005 10:25:59
 Re: Cohocton/Full Pull H in reply to Kevin, 09-26-2005 19:17:01
is this cohocton NY you are refering to?
Kevin
09-29-2005 17:50:34
 Re: Cohocton/Full Pull H in reply to upperpinecreek, 09-29-2005 10:25:59
Yes it is, im not so sure that im going anymore though, turns out last drag race of the season is the same day and im trying to sell my drag racer to buy my own suit case weights and i know someone that want to take it for a test run on oct 9th. Same day as the pull.
Full Pull H
09-27-2005 16:43:03
There maybe somebody that you can borrow weights from at the pull,but i can not garuntee so use your best judgement.As far as classes go they start at 3500 and go in 500 incriments untill 6500 and then 1000 to 8500 so you could get an extra class or two! If you don't make it have a great winter and see you next season.
Kevin
09-28-2005 13:36:15
 Re: Cohocton/Full Pull H in reply to Full Pull H, 09-27-2005 16:43:03
So there is a 5000, 5500, 6000, and 6500?
FarmerSid
09-28-2005 04:55:13
Go to your local dealer and see if they will lend or rent you some.
Cheers!
Sid
