Old Mallory Distributer for tractor?
Junkman10
09-26-2005 02:16:30
I picked up an old Mallory distributer the other day it is on a 90 degree drive. It looks similiar to a delco unit for farmall M. The drive was painted orange at one time. I don't have the part# with me but can get it. I spoke with a tech person at Mallory, he said there was no info on record for part this old, 50+ years. He said it could be a replacement for tractors. It is a single point unit. I tried coupling it with a hydralic pump For a 56 farmall I had laying around, it would take some clearancing to make it bolt up. Does anyone no anything about this distributor setup? I can email pics.
driller1324
09-26-2005 18:28:00
 Re: Old Mallory Distributer for tractor? in reply to Junkman10, 09-26-2005 02:16:30
Does it have a mechanical tach drive on it? If so and you dont want it i may be interested... Let me know
John T
09-26-2005 08:05:43
Junkman, this is the kind of rigging thats close to my heart. I love to rig up all sort of different brands of equipment together to make up what my daughter refers to as "Frankensteins" lol.
I guess so long as you can get it timed so the points break open each time a piston gets to TDC on its compression stroke and at that time the rotor tip is lined up with a cap tower terminal leading to the correct cylinder, she can work. However, unless youre running at such extreme way higher then stock coil voltages that youre afraid the stock distributor cap cant handle the higher voltage and internal cap arcing might occur (which I seriously doubt) I dont see much if may advantage over the stock distributor ????? ??? It may also have an advance curve "possibly" superior to the stock distributor, but youre not running the range from 1000 to maybe 7 or 8 thousand RPM like a race engine, so unless you can couple it to a Dyno and play with the advance curve how you ever gonna know and tune it anyway????? ?? At high RPM you obviously need more spark advance, but the curves on the stock distributor could also be modified if one has the equipment to figure that all out.
If I were a serious puller and running at high compressions I would definitely NOT use mechanical points to switch my coil current, but an electronic switch coupled with a high energy coil running at a wider plug gap. The thing I would wonder about is if you can get an electronic switch to mount inside that Mallory Distributor as easily as you can buy for the stock Delco distributor????? ? Its the elec switch coupled with a high energy coil that you need instead of whether its the stock or that Mallory Distributor. I see them as more the old technology when racers wanted to run at extreme high RPM and the stock distributors experienced point float and/or bounce problems, so the Mallorys were indeed built superior for when extreme high RPM's posed mechanical problems. Im NOT sayign they arent good n superior units, Im just saying at the way relatively low RPM youre running (compared to race engines 8000 RPM) theres no reason why the stock distributor (so long as no high voltage arcing problems) wont do nearly as good, especially if you toss the points and use an elec switch.
Its still no doubt a superior unit versus the stock and sure cant hurt nuttin if timed right !!!!! but see if you can get an elec switch to fit as easily with the stock distributor is my advice before you spend too much on modifications maybe????? I guess even its points to be superior so it would be a better unit over a stock distributor in general, but I dont see using points anyway in pulling, so theres not so much of advanatge left of the Mallory other then maybe higher voltage withstand ratings, but I dont think they experienc much of arcing problems on the stock rotor and distributor cap assemblys anyway that Im aware of.
ITS your tractor and your call. Its just my experience that pulling tractors that run way lower RPM then racing engines and less compression dont need all the super hot rod type modifications maybe????? ?? I would still run an elec switch and hot coil over mechanical points, but dont see Mallory distributors or even the MSD boxes gaining much if any HP above n beyond that. Only way to tell fer sure is couple it to a Dyno and try different ignitions n see what happens I reckon.
Take care yall n God Bless
John T
Cody
09-26-2005 06:25:07
Mallory has made and still makes replacement dist. for tractors. I have seen a couple like you have. They still make repacement dist. for olivers. If you go down to the local AGCO dealer and ask for a new dist for a 1650 oliver, you will get a new billit mallory dist. They work great and look good too!
