Pulling Mag or Distributor, Witch is better for Pu
Miller49G
09-25-2005 05:50:00
I was wanting some input for a John Deere G. Witch would be better Pulling Mag, or Distributor with a MSD box on my John Deere G. My buddy swears by the Pulling Mag. But I"m not convinced on that yet. What type of Pulling Mag"s do you guys use, and how do you guys like them over a distributor set up with a MSD box. Any help or information would be helpful.
Miller49G
super a dude
09-25-2005 21:49:56
 Re: Pulling Mag or Distributor, Witch is better fo in reply to Miller49G, 09-25-2005 05:50:00
i would run a good hot mag. lighter, and mags can be made to be hotter then distributors. www.magneeders.com
John T
09-25-2005 10:31:18
Miller, back now so a lil more. I see the MSD being necessary more so on extreme high RPM (maybe over 6500) racing engines running very high compresion and exotic fuels. That John Deere G at say 125 to 150????? compression and say 1500 RPM with maybe 94 octane gasoline ??? may not gain much HP on a Dyno versus an ordinary electronic ignition thats using a high energy coil. HOWEVER the only way to tell for sure is to Dyno her, still, the MSD sure cant hurt anything versus a standard high energy elec ignition system so pay your money n take ur choices lol.
Back to the Mag question, I CANT SAY FOR SURE without actual energy data but I still find it hard to believe a Magneto (even a super high performance pulling mag) runs at higher energy then even a standard electronic ignition system that uses a high energy coil. Again, the only way to test performance for sure would be to Dyno it with each ignition system, but generally speaking I would choose an electronic ignition coupled with a high energy coil (like the Pertronix switch and flame thrower coil etc) over a pulling magneto anytime anyplace. Then ONLY if youre at super high compression and high RPM and exotic fuel (which your G is likely NOT) would I expect much if any HP increase if you went to an MSD box.
As compression rises it takes more voltaqe to jump the plugs gap, thats why you need that elec. switch coupled with a high voltage high energy coil and run a wider plug gap for a fatter hotter more surface area spark to better ignite the fuel versus a stock ignition system or a mag which may not be capable of achieving high enough voltages.
If the compression wasnt all that high you may not see much more (if any) Dyno HP from a pulling mag versus an elec ignition, but as compression rises the elec system MORE THEN LIKELY shines but given the cost n choices I still WOULD OPT FOR THE ELEC IGNITION, regardless if an MSD box or the more basic systems such as Pertronix.
Nuff said, its your call
John T Nordhoff in Indiana, retired electrical engineer
John T
09-25-2005 07:26:59
Miller, even with a good hot pulling Mag, its hard to get as much spark gap energy discharged across a plug gap as with a battery powered high energy coil type electronic ignition system. More spark energy becomes more important at super high compressions and exotic fuels. So if youre only at moderate compression the mag can produce sufficent spark energy to sufficieny ignite the fuel, but if youre at extreme high compression I would advize an elec ignition system, mSD or otherwise,
Gotta go to chirch I can add more later
Miller49G
09-25-2005 17:44:42
 Re: Pulling Mag or Distributor, Witch is better fo in reply to John T, 09-25-2005 07:26:59
John T,
I would have to say you are write on the money about the Distributor and a high energy coil. I"m new to pulling the John Deere tractors. But I have a Mustang Cobra that I race on the quarter mile strip and I know I need a lot of spark with 16:1 compression and 116 octane race fuel. I though the distributor would be better. But I like to know what everyone else is using for pulling. My mods on the John Deere G are as follows. High compression pistons, pulling cam, and pulling carb, and Jerry"s Weld & Machine manifold.
Bus Man
09-25-2005 12:36:34
I was reading the posts and thought I'd get your thoughts on what the plug gap and voltage output should be for this application. '51 JD G 260 PSI cold, not stroked, 110 octane fuel, 10% over RPM, Mallory super coil w/points with a resistor in the primary circuit. I don't have a generator on it so it just runs battery voltage. Thanks.
John T
09-25-2005 20:55:31
 Re: Pulling Mag or Distributor, Witch is better fo in reply to Bus Man, 09-25-2005 12:36:34
Sorry Bus Man, with no specs or data or curves whatsoever in front of me I (or I doubt anyone else accurately) cant say what voltage is required to arc current across what distance plug gap given that high compression n fuel.
HOWEVER I can lay some engineerign opinions on ya, them and a buck may get you a cup of coffee provided its NOT Starbucks lol but thats for Yuppies n not tractor pullers anyhow lol
At that compression and even given a Mallory Coil I SURE WOULDNT BE USING MECHANICAL POINTS BUT INSTEAD AN ELECTRONIC SWITCH
UNLESS you have an electronic control box where the points merely trigger it and they DO NOT switch the actual coil current????? THAT WHAT YOU HAVE?????
Heres the deal: Mechanical points bounce n ring fairly bad as opposed to the faster and more positive switching of coil current then a solid state device can. An elec switch can improve even a stock coils performance BUT NOT NEAR AS WELL as when coupled with a high energy coil. In order for that Mallory Coil to provide all possible, it would do much better if you used an elec switch. The problem with points n condensor is they were designed to switch around 4 amps max and to store more coil energy you gotta be pumping more amps through it. However when you switch higher coil currents, the points burn up n carbon up much quicker and become resistive which really hurts the coils performance, so thats why when running a hot coil you ought to be switching its current with a solid state device.
An old stock coil may only be capable of rising to 15,000??? or so volts, but at high compression it may take more like 25000??? volts to arc jump the SAME plug gap, so then you need a high performance coil thats capable of ramping up to that necessary higher voltage. Buttttt t that may mean higher coil current and thats when the 4 amps the points n condensor were designed to switch gets exceeded.
Like I say, with no curves or data I cant tell you the voltage required to arc jump current across a given width plug gap at a given compression, but will hazard a pure guess as to what you might be looking at.
Lets say at stock it might take 10000 or so volts to arc a 0.025 plug gap. If the compression goes from like 125 to 200, it may take 20000 or 30000 or more volts to jump the same 0.025 gap, so that likely requires a 30000 to 40000 volt coil (NOT a stock).
Regarding the plugs gap setting, it takes more voltage to arc a wider gap, but a hot coil and an elec switch CAN DELIVER THAT. The advantage of a hot coil and elec switch is the ability to still arc current across a wider gap MEANING YOU GET A WIDER FATTER MORE SURFACE AREA SPARK to better ignite the fuel. HOWEVER theres engineering trade offs cuz as you widen the gap (for a wider spark area) then either the arc current or the spark time duration will lessen, so you cant keep running it wider n wider cuz eventually performance gets worse.
My best GUESS would be to run a plug gap in the 0.035 to 0.050 range and have an elec switch and high voltage coil and you might be firing at voltages in the 25000 to 35000 range?????
A Dyno hook up would be the only way to experiment with plug gaps versus HP, but the firing voltage isnt somethign you can adjust, it depends on the compression and fuel and plug gap ASSUMING THE COIL CAN DELIVER ADEQUATE VOLTAGE. If you use mechanical points to switch actual coil current (NOT trigger an elec box) Im afraid you cant over widen the plug gap cuz you will eventually go beyond the ability of that system to deliver, at least without burning up points very quickly, but with an elec switch and hot coil, you can likely run a wider gap and reach that sweet spot of wider plug gap versus the ignition systems capability to max out HP on a Dyno.
Remember, thers lots of pure guesses goin on here, so NO WARRANTY EXPRESS OR IMPLIED LOL
John T
Bus Man
09-26-2005 04:54:15
 Re: Pulling Mag or Distributor, Witch is better fo in reply to John T, 09-25-2005 20:55:31
Hey, thanks for the info. I'm running straight points and no switch box. That was my concern, that with a wider spark gap I'd need more voltage and could this system produce that. That will be one of my winter projects to look into an electronic ignition system. Thanks again.
Bus Man
