Starter Question
KEVV
09-22-2005 19:11:51
Hey all
I have a W-9 that is bored and stroked,the problem is the starter has a hard time turning it over.
I run a 12V battery and a 6V starter, what can I do to get it to crank over better?
Want to keep the stock starter.
Thank you
Redman
09-23-2005 04:37:07
 Re: Starter Question in reply to KEVV, 09-22-2005 19:11:51
get a starter off of a diesel.
John T
09-22-2005 20:10:21
Kev, if the starter is for sure in good shape???? other electrical things which might improve cranking are:
00 Gauge Battery n Starter n Ground cables with those hig amp rated heavy duty terminals (not the light cheap crimp down type) Attaching the ground cable direct to or as close as possible to the starter itself versus some sheet metal somewhere.
Use of the highest rated CCA or Amp Hour battery as possible.
A known good starter switch or solenoid
Start timing certainly NOT on the fast end
No way of partial compression release petcocks or something like that I take it???
Good Luck
John T, retired electrical engineer
KEVV
09-24-2005 19:55:34
 Re: Starter Question in reply to John T, 09-22-2005 20:10:21
John
The starter SHOULD be in good shape as I brought it in to get rebuilt at the same time I rebuilt the motor.
I have 00 cable with the soldered ends and the ground cable is 2 feet long with the connections clean.
The battery is 750 cca and I bought it new this year.
The starter swithch is the stock one that mounts on top of the starter.
Compression release is a option but that will be my last one.
Thank you for the help
