Need Sleeves for 5-2 Powerblock
jd b puller
09-21-2005 14:42:10
Hi all, I am needing a sleeve for a 5=2 Powerblock. If somebody could tell me how to post a picture, I"d show you why...
THanks, Ray
Phil Munson NY
09-22-2005 08:00:46
 Re: Need Sleeves for 5-2 Powerblock in reply to jd b puller, 09-21-2005 14:42:10
Sorry if its a little O/T. I cannot remember is the B/50 PB 5 or 5.5? Thanks. best Phil
jd b puller
09-22-2005 08:36:34
 Re: Need Sleeves for 5-2 Powerblock in reply to Phil Munson NY, 09-22-2005 08:00:46
Phil: Stock PB is 5 inch. I am working on getting some CAST at 5.5 or 5.75 (Gets really tight on the upper outer bolts). I just want to get this one fixed back to 5.125 for now though. Hopefully will have them at a reasonable cost this fall.
Phil Munson NY
09-22-2005 20:13:37
 Re: Need Sleeves for 5-2 Powerblock in reply to jd b puller, 09-22-2005 08:36:34
the Cummins M-11 in my truck is 5.125 bore and 5.625 stroke; sort of, maybe, without checking the manual. The old 855 - N-14 is 5.5 bore 6 inch stroke. There are gobs of them around, might they possibly adapt easier than having a speciality jobber make up some? Just a thought. best, Phil
JDGnut
09-21-2005 19:20:43
JD B Puller... Stopped in and saw WTW for a min the other day.. Ouch.. that was ugly.... I mine was bad with the 1in hole in the side of the block.. Man.. Mine was nothing.... To post a pic.. you will have to post the pic at another site.. (I use photobucket.com) Once you have it post at anothe site.. insert the info in the Optional Image URL at the bottom of the Followup page... Or you can email them to me.. and I'll post them for you... Good Luck,
JDGnut
