A.C. wd45 rear end diesel or gas any difference?
m. jamison
09-20-2005 19:00:16
I was told that the rear end out of a wd45 diesel, was geared lower than the one out of a gas 45. True or false. If true what is the top speed in first gear?
True
09-20-2005 19:15:34
 Re: A.C. wd45 rear end diesel or gas any differenc in reply to m. jamison, 09-20-2005 19:00:16
Gear speeds are the same. The diesel engine ran faster than gas engine so they slowed rearend down about 14 percent.
Phil Munson NY
09-21-2005 15:48:37
 Re: A.C. wd45 rear end diesel or gas any differenc in reply to True, 09-20-2005 19:15:34
Nebraska tests show the top speed for a 45 gas @ 1400 RPM to be 11.25 MPH on 13-28 rubber. The 45 diesel @ 1625 RPM to be 12 MPH on 13-28 rubber. My guess is that they are the same ratio. best, Phil
