Super M V8
MEZ25
09-20-2005 16:24:46
I am posting this message in hopes of finding some information on pulls in areas other than Central PA. We have a Super M w/ a 468 Buick V8 that we would like to travel and pull against some other tractors around the country. I found the COATPA site and they only allow small blocks, I was wondering if anyone had some information for me other than open classes.
Midnight McCormick puller
04-13-2006 10:17:58
 Re: Super M V8 in reply to MEZ25, 09-20-2005 16:24:46
At Mile Branch we have 2 classes and it is the 3,000rpm class and the 5,000rpm class the 3,000 we pull three weight classes, 5500 6000 and 6500 classes. The 5,000 we have two classes 6000 and 6500. We pull them every Sat. behind Cope's John Deere in Alliance, Ohio. hope you come because we have anywhere from 12 to 26 tractors in every class. We allow up to 512ci. We have a McCormick W-06 that we call the Midnight McCormick and it has a 500ci Caddy in it.
Ohio puller
09-24-2005 18:16:32
Mile branch pull date is Oct. 8th.
Ohio puller
09-23-2005 16:43:25
There is no web site for the club, but the club is Columbiana County Antique Tractor Pullers and they pull every month at the Mile Branch Grange on Saturday evenings. That is located just off RT62 about 4 miles east of Alliance, Ohio and about 9 miles West of Salem Ohio. At the John Deere dealer turn south on Knox School road, go about 1 mile, grange on the right. They run antique v-8 classes 500 cu.in. max with 3000 rpm max controled by chip in MSD. They pull 3 or 4 classes starting at 5500. Weight in at 4pm and pull starts at 5 pm. Next pull should be Oct. 1st and I beleave that is the last one. Also max tire size is 18-4-38. You must be a member to pull, that's $10.00 and it's $10.00 per hook with a 40% payback to the top 3 places. Most nights have about 15-18 v-8 tractors show up. I'm not sure if they let small blocks in or not, all I've seen are big blocks. There are some other pulls in the area that pull v-8 some 3000 rpm and some 5000 rpm. I hope this helps you.
Lvillepull
09-20-2005 19:17:15
Here are two pulls in north centeral Ohio. Marshallville club's last pull is this Saturday (9/24/05) They run 5000 rpm limit and 10mph speed. Full rules and information at link below
If your rig is a little more open, Loudonville is having a pull Oct. 7. Rules are available at www.loudonvillefair.com
You may also want to check out the discussion board at www.masseyharris.com. They have some V8 classes in North Eastern Ohio listed there.
