Petcocks for a JD A power block
Florian
09-20-2005 16:04:47
Is there a way to put petcocks in a JD A power block?
thanks
Drew
09-20-2005 17:41:05
 Re: Petcocks for a JD A power block in reply to Florian, 09-20-2005 16:04:47
Drill up from the bottom and go thru the headstud directly below the cylinder. Then tap it for 1/8" pipe threads. You will want to put a punch in the hole when you torque the head to keep the stud from rotating.
