pinion and ringgear 966
Klein Rot
09-18-2005 03:59:06
Hi,
A friend off mine is looking for a ring and pinion gear for his 966 pulling tractor that can handle the extra power from his engine. Is there a heavy duty ring and pinion set for this tractor.
Sheepdog
09-20-2005 08:36:32
 Re: pinion and ringgear 966 in reply to Klein Rot, 09-18-2005 03:59:06
The ring and pinion is not the weakest spot, unless he had trouble. The TA input shaft will twist off first, go to a 1566 TA shaft. What type of pulling is the 966 doing?
Redman
09-19-2005 05:14:43
all of the SS tractors that have a cast rear left run a stock ring&pinion.
all the same only different ratios,1566/1586 would be the fastest.
grandad
09-19-2005 17:44:38
 Re: pinion and ringgear 966 in reply to Redman, 09-19-2005 05:14:43
I thought 706 is the fastest??? Clue me in on the 15 ring and pinion
Redman
09-19-2005 19:34:58
 Re: pinion and ringgear 966 in reply to grandad, 09-19-2005 17:44:38
15s had planetary rear,had to speed the ring and pinion up to compensate.
i can not remember the tooth count off the top of my head,but it is more than a little faster.
grandad
09-18-2005 16:36:48
I don't know if there is a heavy duty one available. But I have a like new ring and pinion for a 966 hydro
