MW Crank?
junkman10
09-16-2005 21:41:03
Did M&W make a welded stroker crank, would it still have a factory casting #'s with M&W stamped in. Or are all M&W stroker cranks forged with the extra 1/2" and M&W cast in? Did they make small ans large journal cranks? What are part #'s? Could someone email pictures? [email protected] is my email. Anybody have one for sale? Thanks.
Trkr
09-18-2005 16:38:10
 Re: MW Crank? in reply to junkman10, 09-16-2005 21:41:03
M+W HI-Torq crank kit for a 450,5 3/4 stroke 4 1/4 bore is #179(326 cid.).Kit 79 would be for stock stroke.Kit 178 was was 4 1/8 bore,177 was 4 inch bore.
Bigmotors
09-17-2005 17:20:33
The M&W crank was cast. (5.750)
The bearings are the same as stock. I think it said on the crank (ADD-POWER)
If you find one-make sure to have it checked for stress cracks. If the crank has a dollar symbol $ it's a Farmall crank. Alot of tractors put those cranks in and farmed with them for a long time. I'd still think you would be money ahead to have one welded, unless you can find one with in the budget.
Good Luck!
ChadS
09-17-2005 10:35:22
I was thinking they were casted cranks, I could be wrong, they had the bearings sold with the crank kits, its just as easy to have the old crank remade into the M&W specs by a machine shop, unless that M&W stamp is critical to you,,,, 5-3/4 stroke was the M&W crank stroke, at least all the ones ive seen were that specs. Chad
junkman10
09-22-2005 12:46:00
 Re: MW Crank? in reply to ChadS, 09-17-2005 10:35:22
Thanks for the info. Does anyone have a good M&W crank for sale or know what the average price is for having one welded and turned is? How about piston kits for 1/2" stroke?
