cut tires
redkev
09-15-2005 18:47:39
I need info on some grinding wheels to cut tires or other ways to do so.Thanks
Dave in MN
09-17-2005 06:17:10
 Re: cut tires in reply to redkev, 09-15-2005 18:47:39
Use a small, hand held electric wood planer, just make sure tire is clean
top cutter
09-18-2005 06:07:30
 Re: cut tires in reply to Dave in MN, 09-17-2005 06:17:10
How well does the hand planer work? Does it take a month to cut a tire? Does it leave marks in the tread? How long do the blades last?
Thanks,
JrRed
09-20-2005 17:24:08
 Re: cut tires in reply to top cutter, 09-18-2005 06:07:30
Hey top cutter the planer works pretty good and does'nt leave marks if you take your time. Cuts pretty quick but you need to let the blades cool. I like to have someone keep air from my compresore blowing on it when I cut my tires the blades stay cooler longer. Only take 1/8 inch at a time helps a lot.
top cutter
09-22-2005 15:54:38
 Re: cut tires in reply to JrRed, 09-20-2005 17:24:08
thanks, may have to go buy one and give it a try.
JDTH
09-16-2005 09:51:43
Try Miller Tire or Speedway Motors for the disks for the 4.5 and 7" grinders. There is probably other sources as well.
