Weight Loss for M
Leee
09-15-2005 07:22:43
I have been pulling my M in Div 2 for a couple years. I would like to get in to the 4500# class. The tractor weights 5200#s now and needs to lose 500#s. The 4500# class is really 4700#s allowing 200#s for a driver. I hope to replace the cast rear wheels with 9 bolt hubs and one piece 14 inch press wheels. Will I get to 4700 just by doing that? I already removed the hydraulic belly pump.
Thank you
Ohio M Puller
09-16-2005 15:14:58
 Re: Weight Loss for M in reply to Leee, 09-15-2005 07:22:43
I have an Aluminum deck plate for an M if you are intrested. I just got it from Brad Begeman, it looks exactly like stock. If interested call me at 419 295 4592 Adam.
Ohio M Puller
Tedd
09-17-2005 13:19:56
 Re: Weight Loss for M in reply to Ohio M Puller, 09-16-2005 15:14:58
Adam,
Call me monday Ted
Jason(PA)
09-15-2005 18:15:25
Yes,you should make it. If I remeber right the cast Iron wheels weigh about 280 lbs. Get rid of alot when you loose them with pressed steel wheels.
