88 diesel
lafngas
09-09-2005 09:43:31
How good a puller do these tractors make is it hard to turn up the pump and rpms on this tractor or would a 77 gas be a better choice
smokey88
09-12-2005 17:48:40
 Re: 88 diesel in reply to lafngas, 09-09-2005 09:43:31
ive got an 88 diesel and they are rerally good pullers. Its not that hard to turn the pump up but you have to get more air to it also. i would take of the original oil bath and but a regular cone air filter. It will help. Good luck building youre 88 puller
slowsmoke
09-12-2005 03:39:54
An 88D makes a good stock puller. rpm's are a spring on the outside of the pump. (this is a 4 main motor with only drip lubrication for the con-rods, so you don't want to spin it very fast)
as far as more fuel, that's easy too, but more fuel doesn't equal more hp, you'll only burn so much in a NA linova fuel cell engine. Good luck, have fun SS
