gears for G JD
HLW
09-07-2005 12:56:43
also, what gear can I pull in at 6500-7500? G is stock but runs very well. thanks for the help!
38jdhaypress
09-10-2005 16:34:43
 Re: gears for G JD in reply to HLW, 09-07-2005 12:56:43
i have a 45 GM and i only run 1st gear, its stock with 149x38s on it, i only get about 80 feet when i tried 2nd, 1st gets me down there.
Nothing Runs Like A Deere
09-09-2005 14:45:43
Gears is something that I think about a lot.
Last night I ran 4th, 5500 pound class with 18.4x38 tires... 306feet. This was a loose, wet kinda sloppy track. If it had been a hard track... 2nd or 3rd... more then likely 3rd.
Tires size, horse power,... track, weather.. .everything needs to be looked at close!
super A dude
09-11-2005 20:53:29
 Re: gears for G JD in reply to Nothing Runs Like A Deere, 09-09-2005 14:45:43
and what kinda hp numbers you runnin..... .many more then 412 cubes..lol..... .we have a G that just has .090 m&w's and a flathead, 65hp, everything low gear, kills in the 8000 on a half ways decent track. we used to have it running better and it would handle the 9000, but it has a cracked head and needs torn down..... .
G/MAN
09-07-2005 13:38:08
I doubt you'll ever get out of 1st with a good-running stock "G", and you might even power out in 1st on a good hooking track. Is your tractor completely stock and still has the all-fuel manifold and pistons? Going to aluminum hi-comps and a cold manifold will get you to right around 50 horsepower.
