Lamont--Looking for a POWER BLOCK for JD420
Turtle Gears
09-06-2005 19:58:40
Lamont, I beleive the turtle would pop a little louder if i had a power block, what do you think?T.G.
Lamont
09-07-2005 19:52:50
 Re: Lamont--Looking for a POWER BLOCK for JD420 in reply to Turtle Gears, 09-06-2005 19:58:40
I think it would be hard to improve on the way she pops now. It seems to do really well up to 4500 lbs. when we were playing after the pull the other day. It did good there. I think you just needed a couple of weights on the front and maybe one more pound of air pressure in the tires. It impresses me on how it pulls. Can't imagine what it would do with a Power Block. Did they ever one for it?
Turtle Gears
09-08-2005 04:29:03
 Re: Lamont--Looking for a POWER BLOCK for JD420 in reply to Lamont, 09-07-2005 19:52:50
I am not sure, but I think I have. Just something to think about, may never, who knows? hey are you going to bring your 5000# class tractor to fest pull? T.G.
Turtle Gears
09-08-2005 18:30:32
 Re: Lamont--Looking for a POWER BLOCK for JD420 in reply to Turtle Gears, 09-08-2005 04:29:03
Lamont, I Know the turtle does ok in 4500# but i think i want to go with the 420 power block, so i can start pulling in 7500-8500# classes, probly wont go any heaver-might will just try them frist.T.G. What do you think????? ????
Tyler Neff
09-07-2005 07:06:50
I would go with one of those 7.5 G blocks . I think with some minor grinding it might work.
buickanddeere
09-07-2005 09:25:10
 Re: Lamont--Looking for a POWER BLOCK for JD420 in reply to Tyler Neff, 09-07-2005 07:06:50
May have to dry deck the block. Maybe grind a little off the sides of the pistons so they don't rub. Mother Deere built a souped 430 engine for the later versions of the 440 industrials. A set of LP pistons, a cam from Robert's carb, a dry aircleaner conversion, three angle valve job, valve bowl blending and port matching. Then a dyno tuning session. Might make 40HP with the help of a tail wind on a good day. Could do alright in the 3000 to 3500lb class.
