Farmall frontends for pulling
MikeF
09-06-2005 18:50:47
I may be getting a 47'farmall H and I want to lighten the frontend for better weight transfer what should I do. I recently saw at a pull that guys are making their own fronends but what else can be done. Also how hard is it to get an Aluminum Floor plate made and is it worth it. I plan to make this engine scream when it's finished what all do I need to do to make this happen. (i would like it to get in the 300lb class)
42Farmall
09-07-2005 18:45:37
 Re: Farmall frontends for pulling in reply to MikeF, 09-06-2005 18:50:47
Just curious why you would lighten the front on an H. My H is light in the front when pulling 3500# and under. I try to get all the weight out of the rear that I can.
RichB
09-07-2005 11:39:13
Bob King is the man you need to talk to about the top trans cover,I paid 570 for the one I got for a friend of mine for his M.That was all machined ready to bolt on with shipping included,VERY nice work weighs less than 60 lbs,some being made by others are junk.I don't have his number handy,maybe someone on this site will know it,or Email me and I will get it for you.Rich
52' H puller
09-06-2005 19:46:38
You can make your own front end pretty easy. Get you some steel pipe, a steel plate for the top and you can go to your local hardware or farm store and get a 5-bolt hub and spindle assembly pretty reasonably, I used 12" boat trailer tire and rims. Everyone I talk to the aluminum top plate runs about $500. You find a place cheaper let me know...
superih
09-07-2005 09:48:38
 Re: Farmall frontends for pulling in reply to 52' H puller, 09-06-2005 19:46:38
What size pipe you using for the pedistal? I am building a frontend for a "M". Do you think 3 inch schedule 40 pipe will take the abuse?
AC
09-07-2005 19:05:53
 Re: Farmall frontends for pulling in reply to superih, 09-07-2005 09:48:38
How are things coming up there in the center of the state? You going to have your H ready to pull this year?.....AC
