Farmall M Pullers
Hank L
09-03-2005 20:46:44
I am going to be pulling a stock farmall M . It does have 4" dome pistons but other than that it is stock.Not to familiar with Farmall so I was wondering if there is anything I can do to give me a bit of extra HP.I dont want to go into the engine I was thinking more of different carb or intake or ?? . This is an older M and it still has a magneto on it .Is that good or bad or dont it matter?
MikeF
09-06-2005 18:34:50
 Re: Farmall M Pullers in reply to Hank L, 09-03-2005 20:46:44
Nothing wrong with having a little fun with an M. last weekend I took my 41' M to a local pull and got 5th place with against some real hot tractors. We still farm with ours. We have no idea whats in the motor, never even had the valve cover off. We pull it off the junk row and got it running. Hasn't given us any probs since. That was about 12 yrs ago and I put it on the dyno and it has 47 HP (30 from factory). As far as the Mag when they work there better than a distributer, but if it gets weak just switch it over. High test Gas will help if you can afford it ($3.49gal here in PA) You could also wire the governor spring if you wanted then it would be direct oh yea and just have fun Mabye this will help
colekicker
09-04-2005 09:44:39
Ok, well if I was using this tractor for every day stuff, I'd find another carb that I would modify and put on it when I went to pull. ChadS has described in some earlier posts about how to modify the main jet, and that works. Also, change the governor spring. It will rev up higher and come in faster. You can take your regular manifold and polish the exhaust up as much as possible. This will help free up airflow. About the magneto. I would switch to a distributor. I think they are just more consistent. Thats my 2 cents.
