Rear end oil
Kevin
08-31-2005 16:14:26
What kind of oil do you run in the rear end of your puller. The one i just bought has 10w-30 motor oil in the rear end as it doesnt weight as much as the thick gear oil. Is this fine or should i put in some good gear oil?
TheOldMan
09-02-2005 22:45:30
 Re: Rear end oil in reply to Kevin, 08-31-2005 16:14:26
If you are new at this, and it sounds like you are, then drain that stuff and use some proper gear oil. As you learn, it will be more forgiving of your mistakes.
TheOldMan
