oil level in transmission/rear-end
savsmm
08-30-2005 21:11:22
trying to shed a few pounds.....can i run less oil in my trans/rear-end than what the book calls for when pulling? what are people running, full, half full, none? I'm in the a farm stock class, 3 mph limit, don't use the tractor for anything but pulling, do I need all that oil? what is everyone running for oil level in the trans/rear-end?
TheOldMan
09-02-2005 22:49:58
 Re: oil level in transmission/rear-end in reply to savsmm, 08-30-2005 21:11:22
Some folks run 20W-50 at the full mark to shed a few pounds. I have tried in the past using ATF and, while it did work, the risk of gear damage is to great for nearly everyone out there. Not all you young whipper-snappers are as patient as TheOldMan.
LWD
08-31-2005 00:00:31
what kind of tractor? some boys wire down stirfoam,or spray-on insulation foam but wire it down, then it dont take as much oil to hold oil level.
