john deere 70 diesel, is weak
fielden davis
08-28-2005 17:52:14
i have a 70 diesel , i pulled it awhile back and it when the tractor loaded up with weight it started blowing white looking smoke and lost power.the motor has never been built on the tractor but it shows no signs of being wore out i messed with the fuel rack and opened it wide up.what should i check on next , i would appreciate the help.
720Deere
08-29-2005 10:10:26
 Re: john deere 70 diesel, is weak in reply to fielden davis, 08-28-2005 17:52:14
Immediate loss of power along with white smoke sound suspiciously like a head gasket. Not at all uncommon on a 70 diesel. They really need to be up to 170-180 degrees before you put a load on them.
buickanddeere
08-28-2005 21:05:01
Try her on a dyno and she what she really does. Pull the injectors and reconnect them with the tips spraying away from the engine. Crank with the starting engine and study the pattern from a safe distance. Odds are the injectors are getting tired. Somewhere between the air intake snout behinds the grill and the cylinder head. Odds are there is 49+ years of accumulated oil/dirt, the air cleaner mesh maybe bunged as well. Albert at Renaissance Tractor in Washington State is a leading expert on two cylinders. His price is modest as well. Is the fuel fresh and filters clean?
