335 front end swap part 2
Mopower
08-26-2005 06:56:49
I wanted to get back with the guys advising me in swapping a tie-rod front to a dovetail slot pivot on a 335. I found out only later universals and utility models used the same front casting. The older models could not swap a tie rod type to the dove tail swivel (w/ bearing). The difference is in in the "hump" on the top of the casting. I'm installing a small MM single front fork on my Utility. I compared an old 335 parts book to Kevin Moschenrose's newer one and found a casting difference. Thanks for all the input. I'll keep you posted!
