Cam Timing
mshultz
08-24-2005 16:53:13
Got the cam for my tractor and went to degree the camshaft at .050 lift specs. On the intake valve at about 5-6 degrees before the "big" lift begins, the dial indicator jumps about .010, then stays put until the big lift up. My understainding was that you go from the "base circle" before the small .010 jump for the .050 reading. Problem is, that the closing degree reading that I get at .050 is about 5-6 degrees off too - if I use my .010 from the base circle as my 0.000 point I'm pretty close to right on on the closing side of the cam..... what gives?
Haven't tried the exhaust to see if it's the same way - just wondering if there are any pros out there at this that could give me a heads up before I move stuff around to check another one.
Gary Baker
08-26-2005 05:34:09
 Re: Cam Timing in reply to mshultz, 08-24-2005 16:53:13
Use the intake cam lobe centerline. From my experience the base circle is not reliable on most reground camshafts, thus throwing off .050ths
lift points.
Goldsburg
08-25-2005 17:53:59
You need to take your measurements from the 0.000" of lift point. The little .010" of lift that you are seeing is built into the profile. This little bump before the big lift prevents valve train slap as the clearances are taken up and the little "step off" at the end of the ramp (if I understand your description correctly) is to decelerate the valve train prior to close so as not to have valve slam shut.
This is nothing unusual, just go with your gut and don't overthink it...
Good Luck,
Goldsburg
B Barenie
08-27-2005 18:38:37
 Re: Cam Timing/Goldsburg in reply to Goldsburg, 08-25-2005 17:53:59
what is your opinion about advancing cam with an off-set key, when stroking a crank and maintaining stock rod length ?
Do you have an opinion on when the exhaust valve closes on power stroke ?
bud barenie
Goldsburg
08-28-2005 14:25:05
 Re: Cam Timing/Goldsburg in reply to B Barenie, 08-27-2005 18:38:37
Bud -
I wouldn"t say that there is a hard and fast rule for advancing the cam after stroking. It would really depend on the cam profile and the profile"s lobe center(s).
I have seen the exhaust opening on "good cams" range from 28 to 43 BBDC, depending on the size of the engine, RPM range, and flow capability of the head.
I know that this probably didn"t help much, but generally speaking the bigger the engine, the earlier before BBDC you will need open the exhaust valve to adequately clear the cylinder. Similarly, the better the cylinder head flow, the later you can open the exhaust and still properly scavenge the cylinder.
Regards,
Goldsburg
B BARENIE
08-29-2005 17:11:09
 Re: Cam Timing/Goldsburg in reply to Goldsburg, 08-28-2005 14:25:05
ON A MEDIUM BUILD UP APROXO 100CUBES, OPENING THE EXHAUST VALVE EARLIER, (CAM IN ROTATION WITHOUT CHANGING DEGREE SEPERATION) WILL ACTUALLY HELP LOW END TORQUE, i'M NOT UNDERSTANDING THE MIDDLE OF THEE MOTOR AT ALL. PERIOD !
