identifying an IH 301
family traditio
08-22-2005 19:24:24
Found a six cylinder IH engine, the owner says it came off of a combine, he does not know what combine. How can I find out what 6 cylinder it is? Can someone give me some #"s to look for?
Buzzman72
08-22-2005 20:03:26
 Re: identifying an IH 301 in reply to family tradition, 08-22-2005 19:24:24
Don't know about combine blocks, but the 806's all had a large "301" cast into the side of the block...couldn't miss it! On the corresponding 6-cylinder truck engines, on the passenger side of the block, just below the head and just behind the water pump, is a machined pad which [usually] has the engine size stamped into it, with the engine serial number just below that.
Hope this helps.
560
08-22-2005 20:01:40
On the manifold side of the combine block, should be a surface just behind the Alt. bracket. A nice flat spot, being stamped verticle, the cubes should be stamped in there. Just rember, just because it says its a 263, the comp. is higher, a bigger carb, better manifold, and they have a RPM maintaining governer. These 263's in a combine will produce up to 110 HP and still be under 2300 RPM. We have a couple that we pull, and we have stomped alot of high dollar tractors!
jakee
08-22-2005 20:38:28
 Re: identifying an IH 301 in reply to 560, 08-22-2005 20:01:40
the 301 in the 715 combine makes more power than the one in the 806 tractor. combine motor has more RPMs and hi-compresion, in the combine they called for premium gas.
