sealing h. g. oliver 77 more info Earl.
las
08-21-2005 13:52:50
Th is motor was just built 2 mo.s ago by a good mechanic in a good machine shop ever thing should be ok. Yes this copper gasket coming is 31 thousands. my main quesion is that if last gasket that was compound was put on with no copper spray the first and leaked water ,then pulled up and sprayed copper sealer on retighed again to stop water leak. this head was off 3 times with the same gasket so it was crushed 3 times. Is this why it blow, and if so how would you seal the next one that will be copper .Feel free to call and I will call you back on my nichel 802-626-3202 Thanks LAS.
Earl-IL
08-22-2005 09:50:32
 Re: sealing h. g. oliver 77 more info Earl. in reply to las, 08-21-2005 13:52:50
LAS, Compression lbs.? Did you "O" ring? Is it cracked between the sleeves? Do you have sleeve flange .003-.004 above the block? No sleeve flange? Block & head within .002.003 flat?Please give us this info so we can help you. Earl
