the right tire set up for a JD A'
mark sd
08-21-2005 11:32:15
I'm currently pulling my A' with 12.4" tires. After the every pull that I go to the conclusion is always the same. I need more traction so I can actually compete. What would be the best tire/rim size to go with?
52 A Boy
08-22-2005 06:33:49
 Re: the right tire set up for a JD A' in reply to mark sd, 08-21-2005 11:32:15
I pull 16.9x38"s on mine in 7100-8100 Div.2, does just fine.
730-LP
08-22-2005 05:52:12
15.5 x 38 firestones field &road work well
Mike n Mo
08-21-2005 13:00:00
I run 18.4X34 or 18.4X38's on mine. Mike
mark sd
08-21-2005 14:15:59
 Re: the right tire set up for a JD A' in reply to Mike n Mo, 08-21-2005 13:00:00
you don't think that 18.4's are a little overkill? I want to be able to pull farm stock. I was thinking 15.5 maybe 16.9
Steve Van Drimmelen
08-21-2005 14:48:45
 Re: the right tire set up for a JD A' in reply to mark sd, 08-21-2005 14:15:59
Mark, you'll have to forgive Mike, he's an extremist who only thinks BIG!! I pull my 51 'A' in division II or Farm Stock with 16.9 x 34s. These tires fit the rules for the club I pull with as well as the NATPA. There are some local back yard pulls that are locked in to 15.5 x 38s and thats it so check your rules before you decide. Like you, my first year of pulling was with 12.4 x 38s and the results were less than spectacular. Good luck pulling!!!
Steve
Mike n Mo
08-21-2005 18:52:44
 Re: the right tire set up for a JD A' in reply to Steve Van Drimmelen, 08-21-2005 14:48:45
Yeah, yeah, yeah Steve. I know bigger isn't always better, But sometimes it does work. See ya in Boonville. Mike
