sealing head gasket Help !
las
08-20-2005 21:25:32
I plan on using a .0031 copper h. g. on my oliver 77 after blowing the fiber one with copper inserts. that I had problems with water leeking off the oil filter side between head and block. I was first told to put it on with nothing on it,torqet it down,leaked water ,then pulled it up ,copper srayed it replaced head, tighted h. an other 20 lbs. an it stopped. ran it 8-10 hrs. ,and blow the gasket.which was .0035 compound fiber. Iam replacing with 0031 copper and told to use only yamha bond around the oil and water ports between the head and block to prevent the water leak. am tighting to 120 lbs. with oil. Iam hoping it does not leak. I would like any in put for this repair. Thanks Alot
Earl-IL
08-21-2005 08:58:22
 Re: sealing head gasket Help ! in reply to las, 08-20-2005 21:25:32
LAS, Tell us more.How true is your block??? What is the surface finish??? Is the cyl. head true?? Has the block or head been "O" ringed.What kind of comp. are you trying to hold?? Is it just leaking water???I think you might have a typo. error on your head gasket thickness. I hope you mean.031.Let us know we can help. Earl
