What tool for top cuttng your tires?
meanallis
08-20-2005 10:57:06
What tool have you guys used that works well to
top cut your rear tractor tires? Thanks!
Mopower
08-23-2005 05:54:45
 Re: What tool for top cuttng your tires? in reply to meanallis, 08-20-2005 10:57:06
Experimented with a hand planer...cut just like a hot knife through butter!!! I may try it next year on some puller tires.
4010
08-21-2005 10:38:25
I used a hand held planer. Worked very well and it turned out as even on each lug as I wanted them. You can do it your self if you don't want to pay to have them done.
buckmaster 700
08-20-2005 21:15:00
the fastest thing and clean cutting iv found is a 3 in black&decker hand held electric plaine for wood .cuts rubber fast and no sanding dust and very little smoke its smooth .use a electric tire regroover to cut the front
ollie88
08-20-2005 20:15:38
You be better off haveing them done in a machine.Would be cut the same size on each bar and would make the tire bite better! E-mail me if you want to.
TWL
08-20-2005 18:01:35
I have used a belt sander with pretty good results
colekicker
08-20-2005 15:20:01
I have used a #40 Grit flapper wheel. It is not as aggressive as some of the other tools used for cutting. Make sure to watch what direction you are cutting the bars. Some tires cut better in one direction than the other.
