How big are the JD A's now?
jd b puller
08-19-2005 19:48:43
I had someone (computer illiterate) ask me what the going bore/strokes are for the JD A"s being built these days. He"s looking for 2 sizes...
1. What are the upper limits?
2. What size is a good balance of power and life expectancy?
And relative costs and HP of each.
Thanks in advance, Ray
Drew
08-19-2005 20:55:04
 Re: How big are the JD A's now? in reply to jd b puller, 08-19-2005 19:48:43
There are several 6.750 bore A's being built or have been built recently. Put a 9.250 crank behind it for 662ci. With the big bore, a 3.000" pin is a good idea. By the time you put a good Heisler head on it (or spend a boat load to buy a JWMS head and then fix it so its worth a crap), you could probably spend $7000ish on this combo. Should make probably in the 120hp range or so. Also comes w/ the headache of possibly not holding water and sooner or later, it will probably break a crank. Mine is 6.750x9.370 on a 2.750 pin and I will admit it is probably a grenade w/ the pin half way pulled. How long it an engine lasts depends on how it is treated ie: lugged down a lot, compression, if its detonated all the time, etc.
OR
A 6.125 power block with a 9.250ish crank should aproach the 100hp mark for a couple grand less, with a lot less headache. If it is done right, it should be ALMOST bulletproof.
