Re:Will higher RPM's hurt it?
Spencer
08-19-2005 18:20:46
i have a question will turning the RPM's on the tractor hurt it? and will the pump let it go up that high? b/c if i can get our 1486 to turn 3,500 RPM's then i would like to give it a try but i don't want to hurt the engine.
Sheepdog
08-19-2005 19:16:58
 Re:Will higher RPM's hurt it? in reply to Spencer, 08-19-2005 18:20:46
Spencer; The pumps are an individual machine, with there own personality. Some will let you turn them up and some are already there. The 3,500 RPM's will not hurt the tractor. 3,000 is real common tho. The 1486 runs at 2,800 anyway. The pump needs to sent to a pump shop to get the most out of it. A 3LM turbo will help alot. Bigger lines, injectors and you have 350hp. H-2 is all an almost stock tractor will handle and on some tracks H-1.
