Paris Tn.Tractor pull Aug. 20.
rules
08-18-2005 07:55:50
What are the West Tn.rules for farm and super farm? Where in Paris is the pull? Thank You.
Jak
08-18-2005 10:02:32
 Re: Paris Tn.Tractor pull Aug. 20. in reply to rules, 08-18-2005 07:55:50
Super farm can use hang on weights in front of the front tires up to a total of 11ft from the center of the rear axle.Farm stock can't have any weights extending past the front tires.Super farm uses a pulling hitch where farm has to use the FACTORY drawbar setup that they were equipped with and a clevis with no ball.Farm needs to be as close to stock as possible including tire sizes.Super farm has a limit of 16.9 38 up to 6500 then 18.4's permitted.Paris TN is about 20 miles east of Dresden TN on hwy 54 and about 20 miles north of Huntington and about 20 miles south of Murray KY.Hope this helps
Jeff oliver
08-19-2005 13:59:48
 Re: Paris Tn.Tractor pull Aug. 20. in reply to Jak, 08-18-2005 10:02:32
got new kerosene today, coming after ya tomorrow jak! LOL!!!
Where
08-18-2005 13:05:11
Where in Paris? Thank You.
Jeff Oliver
08-18-2005 13:38:59
 Re: Paris Tn.Tractor pull Aug. 20. in reply to Where , 08-18-2005 13:05:11
it is out by the ball fields. Which way are you going to be coming in from? If from the east side go out towards Dresden until you go past E.W. JAmes and up the steep hill. Right as you get to the top of the hill there will be a road to your left. Turn there and go the the second street to the left and turn. You will see the ball fileds down at the end , just go to the parking lot and the track is behind it.
if your coming in from the west go past the Tecumseh plant and go to the top of the hill. There will be a sign there and turn right, then second left and parking lot as above. Need any more info email me and I'll try to help you out.
Hope to see you there and bring lots of folks with ya!!! If you know anyone who shows also tell them as they have a nice shady area for the show.
