rim widening
super_m
08-17-2005 20:38:27
can anyone do it? let me know about prices and things
LeRoy Brown
08-18-2005 18:54:19
 Re: rim widening in reply to super_m, 08-17-2005 20:38:27
It takes about 5 hours to cut,fit weld and grind a set of 38" rims.Plus steel and materials. So you can figure your price on that.At$80 a set that guy is just making peyrole.
randy hall
08-18-2005 15:50:04
i would do it for $100 per wheel sandbasting and primer included.
mo4xdadad
08-18-2005 14:14:16
Where are you located? If your close I might be able to do them for you. We would need the size though for an accurate estimate and how much width to add.
super_m
08-18-2005 14:51:15
 Re: rim widening in reply to mo4xdadad, 08-18-2005 14:14:16
the rims are 11x38's now,i need them widened to 14 or 15 inch. i am located in brookville indiana
mo4xdadad
08-20-2005 12:21:37
 Re: rim widening in reply to super_m, 08-18-2005 14:51:15
I am in sw missouri and could do them for you. Email me if your interested. A 4" job out of 11 gauge will run around $300 for the pair.
mark/sos
08-19-2005 04:02:39
i am located in versailles indiana.
Ohio M Puller
08-19-2005 10:19:09
 Mark is the King in reply to mark/sos, 08-19-2005 04:02:39
Have Mark Bucannan do your rims for you, I have many sets from him and all have been PERFECT! Can"t beat the workmanship for the price. my 2 cents.
Ohio M Puller
mark/sos
08-19-2005 10:27:40
 Re: Mark is the King in reply to Ohio M Puller, 08-19-2005 10:19:09
adam do you still have those 36in step up rims.
mark/sos
08-18-2005 10:34:16
what size you looking for i might have something.
super_m
08-18-2005 14:54:06
 Re: rim widening in reply to mark/sos, 08-18-2005 10:34:16
looking for 14x38 or 15x38 rims to mount on the stock cast hubs for a super m.
mark/sos
08-19-2005 03:59:40
 Re: rim widening in reply to super_m, 08-18-2005 14:54:06
i think i have a set of 14in to fit a cast center for a super m.
super_m
08-19-2005 14:36:55
 Re: rim widening in reply to mark/sos, 08-19-2005 03:59:40
what would you want for the set? i am interested if the price is right.
Mopower
08-18-2005 10:24:57
I heard of a place here in MI that was set up to do it quickly and charged $50 a rim I think. It's steep, but not too bad. I'll try to find out who it was I was talking to.
720Deere
08-18-2005 12:25:45
 Re: rim widening in reply to Mopower, 08-18-2005 10:24:57
You thing that $50 per rim is steep for widening? Do you think that you could cut the wheel, cut and bend the strip and weld two beads around the rim in less than 1 hour? Even if you cut two different rims and welded them together for the extra width, $50 in labor would be cheap.
720Deere
08-18-2005 12:36:03
 Re: rim widening in reply to 720Deere, 08-18-2005 12:25:45
By the way, even a 34" rim is almost 9 feet of weld per joint.
Mopower
08-18-2005 12:27:35
When you put it that way, no, that is a deal. When you look in my wallet, it seems a bit steep. Youe get the idea. Haha. I'd have all day in to a job like that.
720Deere
08-18-2005 03:48:44
It can certainly be done, but it is expensive! I checked a few places and it looked like over $500 to widen a pair of 34" rims. We finally found a Mennonite fellow that would do it for $40 each. It is labor intensive and unless you find someone who doesn't value their labor, you will pay through the nose.
werthfarms
08-18-2005 12:44:57
 Re: rim widening in reply to 720Deere, 08-18-2005 03:48:44
We widen rims for 325.00 for a 38" pair and they need to be sand blasted before i do it if i blast them its another 100.00
