2questions for ChadS
Dale Lee
08-17-2005 06:18:12
I have a M with a 400block and 4.310 pistons wondering what headgasket i can use. 2nd got a 806 bowl and venturi how far can i drill main jet and meatering stem out. Thats it for now Thanks
ChadS
08-17-2005 07:49:50
 Re: 2questions for ChadS in reply to Dale Lee, 08-17-2005 06:18:12
If the sleeve flange is left over you have 2 options, A, have rings made to fit the flange groove, and then you mite get away with running a 450 head gasket. B, copper head gasket. Both methods bout cost the same to have done. All you have to do on the 806 bowl is the main jet increase, the metering stem is large enough, and dont need any mods done to it, unless, you have over 220 psi of compression. Then you may have to drill the bottom 2 holes of the stem. You are running a #35 or a 33 venturi? Chad
