MM engine
ollie man
08-15-2005 19:08:59
I just bought a 1355 oliver to set up and pull in the hot stock classes. I will put a blower and P pump on it and was wondering how big a guy could bore a 585 out or if it would even help to do it since we can only run a 3 LM windmill. An also any ideas to lighten it up besides the obvious and swithing the rearend to a smaller 55 series tractor.
Errol
09-12-2006 22:47:52
 Re: MM engine in reply to ollie man, 08-15-2005 19:08:59
I would like to get a name/number of the guy that can change heads to direct injection
Thanks Email [email protected]
Mopower
08-16-2005 10:10:29
I believe the 55 series were Oliver rear ends. Reverting to a G900 rear end would really lighten things up, but I don't know what you are willing to do or what your rules allow. There is a fella that converts those heads over to accept a standard injector so you can get rid of the funny fuel cell piston thing. I'm not sure how far you could bore the 585. (A HD800 6" crank will bolt in there.)
je
08-20-2005 15:58:21
 Re: MM engine in reply to Mopower, 08-16-2005 10:10:29
585 MM motors are direct injected so they do not have an energy cell , Mr MM super puller
Mopower
08-22-2005 11:39:56
 Re: MM engine in reply to je, 08-20-2005 15:58:21
No kidding. If you read the post I said in the "piston". The 585 engine had a funny shape to the top of the piston to act as a fuel cell, controlling the burn. There is a man that reworks the heads to take later style injectors to work with normal pistons. I'm no super puller, but I wouldn't say it if I hadn't seen it.
gfsabx
08-15-2005 20:11:16
You can go bigger, but I don't think it will help much unless you buy a high dollar charger. I know this is a crazy question, but have you checked into beefing up the bottom end of the motor. I have a few ideas on making it lighter but don't know what you have in mind.
