Loss of compression
Digger
08-15-2005 16:46:36
I rebuilt the the motor in my H had 160 to 165 psi after rebuild. Now after a year of pulling I have 145 psi on all the pistons. What happened to the 20 psi I lost. I thought I would gane more compression as the rings seated. Or is this what I get for THINKING. Open for some knowledge on this. Thanks Dig
Lamont
08-15-2005 20:48:40
 Re: Loss of compression in reply to Digger, 08-15-2005 16:46:36
I run a Case 700 and had the same thing happen after only about 3 hours running. Retourqued the heads on which some bolts gained a full turn. All of them gained at least a hslf turn. Reset the valve lash which had changed remarkably. Rans better than ever. Don't run your valves too tight. A lot of people think less is better. 0.010 is not enough. Widen it on out to at least 0.025 intake and around 0.030 exhaust. Start there and see how you like it. You might even go more.
ChadS
08-15-2005 16:52:00
have you retorqued the head gasket and manifold yet? After,, then readjust the valve lash. On engines Ive done, and got an hour or two on them, Ill see a compression loss, till I retorque bolts and it usually picks right back up. as parts heat up, they expand, and you have to tighten them back down to specs. Hope this helps, Chad
