kill switch on JD G
ollie tude
08-14-2005 08:59:04
I'm trying to hook up a kill switch on a '38 unstyled JD G. There are no outside posts on the magneto. I pulled the cover and can't figure out what would be the negative side. HELP!!!
Thanks a million
John T
08-14-2005 09:39:55
 Re: kill switch on JD G in reply to ollie tude, 08-14-2005 08:59:04
Ollie, the way to kill the spark on a magneto is to dead ground the points to the mags metallic case. On some mags like a Wico X Series, they had that lil external kill switch stud used to short out for the kill function. If your mag dont have that you need to get a wire into it somewhere thats attached to the points (same place condensor is attached) and have it in series with a normally open pull safety switch (like an electric trailer brake safety switch) and the other end tied to ground, preferably the mags metal frame.
John T in Indiana, retired electrical engineer
ollie tude
08-14-2005 10:56:46
 Re: kill switch on JD G in reply to John T, 08-14-2005 09:39:55
John T,
that answers my question. It is a Wico C series, with no external stud. I got it figured out now. Thanks.
John T
08-14-2005 12:38:02
 Re: kill switch on JD G in reply to ollie tude, 08-14-2005 10:56:46
Ollie, if that G has been souped up and youre running real high compression??? and youre a serious puller, it would need either a high performance Mag like Robert Beaver (Roberts Carb Repair in Spencer Iowa) n some others (Magneeders or McDonald Ignition) build or better yet a battery powered electronic ignition. If youre just messing around at stock pulling and arent at super high compressions the Wico C mag will likely produce a sufficient spark, but not as good a Wico X mag with a hot coil (also available from Roberts n the others)
Good luck, John T
Nothing Runs Like A Deere
08-14-2005 19:03:36
 Re: kill switch on JD G in reply to John T, 08-14-2005 12:38:02
If you want a WicoX from Roberts ive got one! I have no choice to go to the Electronic System because of the fact that im at 10:1 ratio. Let me know if you want a very high power mag.
ollie tude
08-16-2005 21:44:17
 Re: kill switch on JD G in reply to Nothing Runs Like A Deere, 08-14-2005 19:03:36
What does a mag like that run? I'm wondering if it would justify the cost just for a few antique pulls a year. Thanks
