jd 830 tires
Sharpie
08-08-2005 02:08:16
I am just starting to pull at some of the antique tractor shows I have18.4 34,s on right now but would like to go to 18.4x38,radials. Would these tires be to big? I have lots of power in second gear.
Yeoman
08-09-2005 05:23:37
 Re: jd 830 tires in reply to Sharpie, 08-08-2005 02:08:16
Got a set of firestone 151 20.8-34 in the barn if you are interested, Best Phil
LRN
08-09-2005 07:23:39
 Re: jd 830 tires in reply to Yeoman, 08-09-2005 05:23:37
Mr. Yeoman if Mr. Sharpie isn't interested in those 20.8 34's I am looking for a set for my 820. Where are you located and what shape are they in.
Thanks, LRN
Yeoman
08-11-2005 08:00:55
 Re: jd 830 tires in reply to LRN, 08-09-2005 07:23:39
I am in upstate Groton, NY. Tires are about 1/4/ - 1/3 tread. 8 ply., best, Phil
LRN
08-11-2005 18:44:17
 Re: jd 830 tires in reply to Yeoman, 08-11-2005 08:00:55
Thanks for the info. I'm in Mich and that might be a bit far to travel. I would like to find something with about75% lug.
Thanks, LRN
buickanddeere
08-08-2005 19:40:26
Double bevel 20" rims with an old hard set of Firestone 23 degree 18.4x38's. Tough to beat.
720Deere
08-08-2005 16:47:15
If your 830 won't pull competitively, it's not the tire size at fault. 18.4s will pull very well on that tractor if everything else is setup properly. It may be the brand of tire more than anything else.
JDBert
08-08-2005 10:00:01
Why not try 20.8x34's? otherwise you'll have to get step up rims to go the the 38's. Plus you'll gain alot of wheel diameter that will affect your ground speeds.
