Portersville K. O. M.
Johndeereyellow
08-07-2005 06:15:47
Who and what came out in top three of the K. O. M. Sat. night and about what weight did the tractors weigh. Any pictures on here would be good. As I am out of town and could not be there this year.
720Deere
08-07-2005 06:46:31
 Re: Portersville K. O. M. in reply to Johndeereyellow, 08-07-2005 06:15:47
As soon as I have time, I will have some pictures. The 720 gas widefront came out on top again this year. The 720 LP came in second. The 720s both claimed to weigh around 30,000 lbs. A IH 450 broke a hub in the next to last round leaving only the the two Deeres. The guy that had the 34,000 lb Farmall M last year had a SMTA this year with 30.5-32 sharpened tires. He ran out of power in the next to last round because he was afraid to use his whoopty doo lever. A 620 ran out of power with about 3 rounds to go and several Farmall Ms spun out in the same round. I think the sled ended up weighing close to 25,000 lbs.
I believe that they had 7 tractors in all with Albert winning again. That 720 LP just doesn't have as much power as the gasser. Any more weight on the sled and Albert would have been out of power also. He barely made it.
We drove nearly 300 miles to see this pull and even after getting home at 4:00 A.M., it was well worth it. I have never seen anything like this before!
pullwatcher
08-08-2005 05:26:07
 Re: Portersville K. O. M. in reply to 720Deere, 08-07-2005 06:46:31
720 gas won again, getting a full pull on the final winning hook. it really sounded like it was running good this year. said he is retiring that tractor from that pull. said enough stress for it. so maybe we will see him on a different tractor next year.
Brian/Pa
08-07-2005 17:38:34
as the flagman, and the guy passing out the dreaded handshake, Alberts 720 gasser still had lots of life left in it.
i think had the hub not broken, the 450 might have had a chance.
the M with the 30.5"s i think would"ve faired better with a set of 23"s, but a fine showing none the less given 3 weeks to come up with something to pull.
all in all i was glad to participate, i think we had a very good pull with some fine tractors pulling ALL nite long. some of the little guys did very well, as did our own little "queen of the mountian".
720Deere
08-08-2005 07:43:23
 Re: Portersville K. O. M. in reply to Brian/Pa, 08-07-2005 17:38:34
Brian,
You did a fine job of hooking the tractors, flagging and giving the handshake! I didn't know who you were or I would have talked to you.
Albert has one fine running 720 gas, but I would love to see a diesel in the hunt. I think it would take too much money to make enough power with a diesel, but it would be fun! Why didn't the SMTA use his t/a? I couldn't believe that he thought he had enough power for those tires without the use of the t/a. If Bill Jones figures out how to make those IH wheels stronger, he will win that event. He still had plenty of power when he broke. Unfortunately, that is the nature of the IH beast as I have seen quite a few high hp 400/450s break the hub and wheel under a load.
I think I have become addicted to this KOM pull and will return next year. I think I will probably have a few more passengers next year as well. You guys put on one helluva show. It's good enough for us to drive 300 miles and be willing to do it again next year. Keep up the good work and make sure that the A-C pull back tractor gets rested up for next year!
Brian/Pa
08-08-2005 17:37:04
 Re: Portersville K. O. M. in reply to 720Deere, 08-08-2005 07:43:23
i've heard from numerous people the same question!
other than the driver, i think i had the best veiw, the T/A was pulled PRIOR to the start of the pull.
i think 20K + in weight wont start to good on the hi side of the torque lol
a few years back we had a diesel 720 pull, matter of fact he won the pull. personally i would love to see an orange tractor in the hunt, but Allis never made anything big enough that would meet the rules.
i'm hoping that someone will come up with "something new" to bring next year.
maybe the MM guys got a few ideas????
redneck_girl
08-10-2005 09:58:52
 Re: Portersville K. O. M. in reply to Brian/Pa, 08-08-2005 17:37:04
i think your right.... my dad runs all allis and we could never find anything that could win it but the "uc" that he uses as the pull back tractor up at portersville puts on quite a show
720Deere
08-08-2005 18:51:03
My brother seems to think that an 80-830 would make a good candidate. They have the power, but unless you have one of the rare 820/830s with the creeper gear, they are geared too high. I also think that they would be too hard to weight down.
I know a few Oliver 880s that could give them a run for the money. The old Super 99 "noise maker" would make a good candidate as well. If Albert truly doesn't run the 720 next year, I think Bill has a good chance of going the distance. If his problem is like what I have seen before with the IH hub, his only option may be to have a steel wedge machined for those wheels. The wedge breaks and then the pieces wedge themselves in the wheel and break it as well. That's why you hear two bangs. My friend has 656 wheels and wedges on a 400 and still broke one last week. The cast wedge is the weak link.
There are some Moline guys out there that can do it. I guess we will see what next year brings. You never know what that sweet young thing on that M will do either! (besides beat the pants off her husband that is)
JD hauler
08-10-2005 12:13:31
 Re: Portersville K. O. M. in reply to 720Deere, 08-08-2005 18:51:03
Not that you could see it, but anything different than stock hubs will get you in trouble with the rules people, must be stock parts as we have said in the past, I do agree it would make them stronger.
720Deere
08-12-2005 03:47:12
 Re: Portersville K. O. M. in reply to JD hauler, 08-10-2005 12:13:31
So what you are telling me is that the SMTA with 30.5-32 tires was running on stock hubs/wheels? I think the rules get bent a little already just to be able to have some competition. Most of the tractors that made it close to the end have some serious engine mods. I've been around quite a bit of pulling and a 720 will run out of power with half that much weight on board. The 450s and especially the Ms had a tad more power than they should as well. So I guess a few thousand dollars in the motor is okay because you can't see it, but a few hundred on the outside is not legal. The hub is a safety issue and should be allowed to be addressed. I don't understand how you could allow all the unsafe weight hanging that I witnessed and not allow someone to fix a weak point on the tractor. I haven't seen it happen yet, but with that much weight on the tractor that wheel could just break off totally ejecting the driver or worse yet go wheeling off into the crowd that is allowed to gather at trackside.
It's the same in all motorsports, the guy with the most money wins! If you have enough money or generate enough money for the sanctioning body, rules are overlooked. This year was my first trip to Portersville and I intend to return next year. I am a die hard John Deere man but I would still like to see some competition. What fun is it for the same guy to win every year with the same runner-up?
JD hauler
08-12-2005 09:27:38
 Re: Portersville K. O. M. in reply to 720Deere, 08-12-2005 03:47:12
720, sure there are mods done, and I too have built some deeres and have been around many others, the point I am making is that I really think the 720 do indeed have stock hubs, the pull is supposed to be that way, build all the weight bars however you like, brace after brace, but the other stuff is suppose to be left alone, I am not wanting a war here, you just have to know these people and their tractors and I really think you would be suprised at alot of things that go on at pulls, so the point is, safety yes, overmodify, no, I think you saw a few good running 70 hp tractors or so,and that isnt that hard to get and keep them together.
720Deere
08-12-2005 18:32:08
 Re: Portersville K. O. M. in reply to JD hauler, 08-12-2005 09:27:38
I'm not really disagreeing with you, just playing devils advocate. John Deere F1500R wheels are nearly bullet proof considering they were originally designed for only about 50 hp. The IH wheels are definitely weak. If you took a good look at the SMTA, you would see something a little different. Those fenders were sandwiched on there for a reason. That along with the wheel weights prevented anyone from seeing what was really there.
I guess all I am really saying is if you are going to have rules, enforce them across the board. That will never happen, it's the same everywhere.
As to the 70 hp, I don't know if I buy that either. I have seen a 450 that I know for a fact was 75 hp run out of power in 1st gear weighted to only 13,000 lbs. I have also seen 60 to 70 hp JD 720/730s run out of power in 1st gear with 18.4 tires and 15,000 lbs. A little bit of stroke goes a long way. Who is ever going to prove otherwise? It costs too much to tear one down for anybody to pony up. Of course checking stroke on a 720 isn't too tough with those handy access plates on top of the crankcase.
I am probably speaking out of turn since I have never seen the rules for this pull. If you have access to the rules, I would be interested in seeing them. It's been good chatting with you, but I better drop out before I make somebody mad.
JD hauler
08-13-2005 13:24:14
 Re: Portersville K. O. M. in reply to 720Deere, 08-12-2005 18:32:08
720, no problem, it is good to talk this kind of stuff over, you guys dont have this type of pull and are very intersted, that is good, if things do work out, maybe others would bring some out of the area tractors to future pulls, that would be great, but dont know if people would bring that kind of weights several hundred miles. yes you are right, rules will always be bent the best they can, if you can get away with it, why not, and not like there is money to loose, right, I dont really think the 720 has a stroke kit, but I didnt see it apart either, so point well taken.
halfbreedm
08-07-2005 19:19:53
you did u good job also Brian.
thanks
IN
08-07-2005 09:07:02
The M from last year was DQ from pulling this year cause JD boys were scared it would win.
