Need alittle more out of my super H
Kidd
08-04-2005 19:45:36
My 1954 Super H is stock with 120psi compression on all four ,I put Chads govenor spring in and its great but I can't place in the second round of pulling. In the first round I pull in 2nd gear and I can make the full pull. In the second round if I pull in second I run out of power and finish 4th. There is a speed limit but I'm just under it in second gear. The rpms are up because of the spring, just wondering if and how to play with the timing to get the most out of my stock motor before stroking it or something along those lines. Thanks
WILDMAN
08-09-2005 10:51:14
 Re: Need alittle more out of my super H in reply to Kidd, 08-04-2005 19:45:36
IF YOU WANT TO RUN 2ND PUT AREGULAR H TRANS GEAR IN IT.
farmall 300 boy
08-06-2005 13:24:44
how bout puttin her in 1st for the second round
